Washer stopped working today with a full load. Gave us an LD alarm which the book says that water is not draining. Hose is clear and all looks good. Removed clothes and drained water but still no joy.
Unplugged and let sit for two hours to reset computer. Still no go. Same alarm.
Any ideas?
Originally Posted by: billsoto Washer stopped working today with a full load. Gave us an LD alarm which the book says that water is not draining. Hose is clear and all looks good. Removed clothes and drained water but still no joy.
Any ideas? check for broken wire at drain pump connector, wire is very small like telephone wire ,may be broken inside insulation
