have a 4 year old Kenmore Washer & for the last year I've had to empty water out of the bleach & softener dispensers after each wash. The bleach dispenser is completely full of water & has overflowed into the softener dispenser. I do not use either bleach or softener. Do you know what would be causing this problem? Thank you.
Probably you need to replace the dispensor assembly, or you may be able to remedy the problem with a cleaning out of the assembly but we really cannot say how to check it or what to do without a model number.
Post one and let's see exactly what machine you have.
Thanks.
