kbl88
#1 Posted : Thursday, December 10, 2009 12:10:16 PM(UTC)
kbl88
I have frontload washer make loud noise when It spin. I just replaced new vibration shock absorber but not making better. Thanks in advance
sidfink43
#2 Posted : Friday, December 11, 2009 1:03:40 PM(UTC)
sidfink43
This is very common with this model. It is likely the rear bearing is failing. You can listen to it and if the sound comes from the rear, that is what it is.
Unfortunately, it is not a repairable item, you have to replace the back half that contains the bearing. Since it is an expensive repair I would advise running the machine until you can no longer stand the noise, then getting a new one.
Sorry not to have better news.
kbl88
#3 Posted : Friday, December 11, 2009 1:42:27 PM(UTC)
kbl88
thanks fot your help. today I just disassembly outer tub and there is the shaft attached to the spider ( 3 wings ) likely 3 arms bolted to inner tub. and 3 arms were broken off , so the shaft is not holding the inner tub. actualy I look in part ( diagram number 4 ( wshr tub, motor) the part AP2107258 is $243.56 + shipping , I dont know what should I do right now . thanks again
#4 Posted : Saturday, December 12, 2009 1:37:44 AM(UTC)
You probably also have bad tub bearings, makes the repair too expensive.
