robert sherwood
#1 Posted : Sunday, November 29, 2009 12:40:07 AM(UTC)
robert sherwood
Hi, I hope you can help me I have a amana top load washer that leaks from bottom how do I fix it?:(
sidfink43
#2 Posted : Sunday, November 29, 2009 11:47:40 AM(UTC)
sidfink43
You need to take off the front panel and observe where the leak is coming from. Since the pump is in front, there is a good chance it is the pump or hoses or hose connection which is easily repairable.
Loosen the screws at the bottom of the front panel and insert a screw driver or putty knife in the gap between the top and front near the edges to relese the clips that hold the front panel on.
Here is the service manual which will take you through the process.
http://www.servicematters.com/m...ary/docs/RS3100005R3.pdf
dishwasher leaking from bottom (Dishwasher Repair)
by kjack45 12/8/2014 8:06:43 AM(UTC)
Hotpoint dishwasher leaking from bottom of motor (Dishwasher Repair)
by Beacon18 10/1/2012 10:45:36 AM(UTC)
Dishwasher leaking from bottom middle of door (Dishwasher Repair)
by grayguy 4/22/2011 6:27:16 AM(UTC)
Amana Washer leaking from bottom (Washer Repair)
by hkasdan 1/11/2011 7:45:34 PM(UTC)
Maytag Performa Washer Leaking From Bottom While Filling (Washer Repair)
by mjones61 11/7/2010 11:00:15 AM(UTC)
Maytag washer leaking from bottom (Washer Repair)
by Famof5 7/8/2010 5:29:47 PM(UTC)
by gricodrywall 12/27/2009 12:51:45 PM(UTC)
Maytag top load washer leaking from bottom (Washer Repair)
by tiffanysinger 6/23/2009 1:14:00 AM(UTC)
Kitchenaid dishwasher leaking from bottom (Dishwasher Repair)
by smithguy 5/22/2009 1:39:19 PM(UTC)
Dishwasher leaking from bottom (Dishwasher Repair)
by FPS 4/5/2009 1:36:03 PM(UTC)
Washer Leaking from bottom. HELP! (Washer Repair)
by ashbranstad 12/22/2008 7:25:22 PM(UTC)
Dishwasher leaking from bottom of front door (Dishwasher Repair)
by kipper 11/14/2007 2:02:21 PM(UTC)
