i just replaced the heating element and still no heat.i was looking at thanging the saftey thermostat do you think this could be the problem??
Forum Rank:: Advanced Member
Here are your parts Replacement parts for GE DVL223EB4WW | AppliancePartsPros.comI would check the thermal limiter, Item 1236 in Section 1, then the safety thermostat 1236 in Section 1. Both should be 0 ohms. If the fuse is blown I would replace both. If the fuse is gone. Clean and check the blower wheel and the vent system. Make sure the lint filter is not coated with fabric softener residue. Check that the drum seals, 1220, 1221 & 1271 in Section 3 are OK If you do not own a meter, I would suggest you purchase a one. You can get a decent digital multimeter for under $20.00. You do not need fancy though it is nice if the leads are a couple feet long. If it saves ordering one unnecessary part it has paid for itself and you end up owning a useful tool. Most places will not let you return electrical parts so if you order it, you own it. A couple things to watch when measuring ohms and continuity 1. Always remove power from the machine otherwise you could blow your meter. 2. Always disconnect at least one side of any device you are checking. This eliminates the possibility of measuring an alternate/parallel circuit path. 3. When checking for closed contacts and continuity use the lowest scale (Usually 200 ohms). Then try higher scales. This scale is 0 to 200 ohms so if the device you are measuring is 300 ohms this scale would show an open circuit which it is not, you are just measuring outside the scale's dynamic range. There is a good STICKY at the start of this forum about it's use. |
THIS FORUM IS DEAD!!!!!!! |
