I have watched the video how to change the bulb(WPW10440740) on a microwave/oven combo and mine looks a lot like it. I removed the upper and lower vent grills and removed the two screws at the bottom holding it in. I even removed a lot of unnecessary screws, but it is not budging. Does anyone have any clues? I feel like there must me screws at the back or sides holding it in. Taking the entire oven out is going to be a huge task that I am trying not to do unless absolutely necessary.
Groups: Moderators, APP Team, Registered Joined: 2/27/2024(UTC) Posts: 0 Location: TN Was thanked: 9 time(s) in 9 post(s)
Cromking, the microwave support rails do have screws at the back. If the microwave does not lift up slightly and pull forward, the wall oven would need to be pulled out just enough to remove the side panels to access the microwave.
