Brant739
#1 Posted : Wednesday, March 13, 2024 3:48:07 PM(UTC)
Guest
Rank: Guest
United States
I have an Amanda NTW4516FW3. The washer gets stuck on sensing fill. Sometimes it will fill, sometimes it just hums. I ran the manual diagnostics and got the error codes. Everything pointed at the inlet valve. I replaced the inlet valve with a new one, the washer worked a few times and then back to the original problem. Ran diagnostics again, got F8E1. Proceeded to replace the control board. Ran the self calibration. Washer worked for a few days and now has the same symptoms as before. Don’t know it this is relevant but the lid lock light only come on during spin cycle and works in diagnostic mode. Out of ideas at this point.
