Rank: Guest
Groups: Joined: 8/10/2018(UTC) Posts: 0 Location: 99556 Was thanked: 4 time(s) in 4 post(s)
I first noticed that the machine would not go through the rinse cycle. Later I realized that the cold water wasn’t being allowed into machine. We used to be able to do a cold water wash. But now the washing machine is NOT allowing the cold water through. If I select “warm water” all I get is Hot water. It’s just not letting the cold water into the machine.
What is the likely repair/part for this problem?
