Rank: Guest
Groups: Joined: 8/10/2018(UTC) Posts: 0 Location: 99556 Was thanked: 4 time(s) in 4 post(s)
I have a Frigidaire Washer/Dryer Combo Model GLGT1041as1 when it starts the final spin cycle there is a audible Squealing noise sounds almost like a slipping belt or worn bearing or pulley Seems to be heard from above or near the top of the unit as opposed to the bottom but noises can travel. From What i have read , it may be a Spin bearing at the bottom of the outer tub need help diagnosing correct part to replace.
A) is it the Spin bearing
B) Can the inner and outer tubs be removed without having to remove the dryer unit on top Its in a confined area closet of the house, not ample room to move unit out of closet
Thanks in advance
