Joe513
#1 Posted : Monday, June 20, 2022 12:49:46 PM(UTC)
Joe513
United States
Parts replaced-
Control panel, water inlet switch/valve, and soap dispenser.
Error codes: E1, E6, E4, F6, and F7.
Laundry list of intermittent problems. Won't enter wash cycle, soap drops in rinse cycle, soap partially dissolved, water cold, no water, dishes not dry. Bizarre - nothing is consistent.
Washer control panel has been reset several times. It will run well for a couple of washes and then back to the same BS. I thought replacing the control panel would fix it.
What I have checked. Water to washer about 70lbs, no blockage in drain hose, pump runs and drains tub, float/water level switch continuity good with no no sticking issues, continuity at thermostat, tub full of water on physical inspection, and heater element is hot.
Could I have gotten a defective new control panel? Any thoughts?
