appliancedummy
#1 Posted : Wednesday, May 25, 2022 1:14:45 PM(UTC)
appliancedummy
Have a side by side wit ice maker Part # 241621902, I have taken in and out 12 times, adjusted water level to make smaller cube size because they were not ejecting properly, which seemed to work. Then noticed after one batch of ice, it would properly fill, freeze then nothing after more than an hour. I used hair dryer to loosen and manually cycle and eject cubes, then it would not stop cycling and just kept going round and round. I noticed the switch attached to the arm that controls the level of ice in try seemed to be stuck and no clicking sound , so I took that out and it seems to be fine. reinstalled and cycled to correct position, stopped and filled correctly. Trying first batch now.
Thanks for some help.
Thank you.
