mid
#1 Posted : Monday, May 23, 2022 12:46:49 PM(UTC)
mid
United States
Hi everyone - I'm having trouble with my double Whirlpool wall oven WOD77EC0HS, with the lower oven that won't heat. No other apparent problems, the display is fine, no error codes, and the upper oven heats properly. The display will indicate that the oven is heating, but does not actually heat.
This happened after a selfclean.
A local repairment came over and without pulling the unit from the wall, said that the board needs to be replaced.
Thank you for your help.
