Allen_M
#1 Posted : Thursday, May 19, 2022 8:57:30 AM(UTC)
Allen_M
United States
All repairs so far done with parts from Appliance Parts Pros.
Nov. 2021, replaced the broil element which failed when it had a blowout. Broil worked fine after the replacement.
May 2022, replaced the bake element when it also failed from a blowout. After replacing the bake element, neither broil nor bake would heat.
Stove top eyes and display work fine.
Looked in the parts diagrams here and in the back of the actual oven, there does not seem to be a fuse for this model.
Both elements check good (14 ohms and 16 ohms).
Terminal block reads 239.7 volts across the two outside terminals.
Questions.
1. Is there a fuse somewhere in this oven? I'd love to find one.
2. If there is no fuse, the incoming power is 240V, and the elements test good, what else could the issue be other than the control panel?
Many thanks in advance to all who answer!
Allen
