Rank: Guest
Groups: Joined: 8/10/2018(UTC) Posts: 0 Location: 99556 Was thanked: 4 time(s) in 4 post(s)
Freezer almost freezes items on the coldest setting, refrigerator seems normal although I do not have thermometer to check. Evaporator fan is fine. Worth mentioning--Ice Maker not working and will only manually advance sometimes. Generally after unplugged and plugged back in. I have had off and on problems with ice maker for years! Thoughts on the freezing matter?
