Paladin7485
#1 Posted : Monday, April 13, 2020 7:59:46 AM(UTC)
Paladin7485
United States
I have a question if someone can answer before I buy a bunch of parts. I have a Speed Queen Washing Machine AWS17NW. For the past few months when you use it, it fills with water fine and the timer continues to next cycle but when it gets to agitate or the spin cycles it stops and the motor hums. You can get it to continue on by hitting it or slamming the door and it will continue on down the cycles again until it gets to final spin and then it stops and hums again. Any ideas? I didnt see any corrosion on the motor contacts. Could it be the timer even though its advancing like it should? Thanks for any help.
airbornebasquo
#2 Posted : Monday, April 13, 2020 3:24:17 PM(UTC)
airbornebasquo
United States
I have seen that on an older model. Pull the dial knob off and check the teeth, pawls, or whatever you want to call them, for damage. I ended up having to replace the knob and the dial/timer mechanism because where they engage has become damaged. Take a look to see if you can note any damage to any of the teeth that should engage when you push or pull the detent part of the knob/dial assembly. You might find you can get by for a while by using an o-ring to help mechanism grab, kind of like using a rubber band on a phillips to help remove stripped screw.
Whirlpool dishwasher repair question (Dishwasher Repair)
by asouth 1/18/2014 12:36:20 PM(UTC)
Neptune Washer Repair Question (Washer Repair)
by flygirl15 2/16/2011 3:32:32 PM(UTC)
Dishwasher Repair Question (Dishwasher Repair)
by rochester,mn 8/31/2010 7:07:27 PM(UTC)
