The broil function stopped working. When in the bake function after an hour the temp only gets to about 260 degrees. I let cool off and tried the broil function and the oven never heated up. I removed the broil element and got a reading of 14 ohms. Which the best I can tell is a good continuity reading.
I would like to confirm that is a good reading, and if so, what do I check next?
I appreciate any suggestions, thanks!
