Welcome Guest! To enable all features please Registers on the forum or Register.
rgcbuilders@earthlink.net
#1 Posted : Wednesday, November 4, 2009 7:19:30 PM(UTC)
My oven will stop heating and code a F3. When it is off it will beep sometimes and code F2. Is this fixable?
#2 Posted : Thursday, November 5, 2009 2:46:55 AM(UTC)
Replacement parts for JTP10GS JTP11WS models | AppliancePartsPros.com
I looked up F2 and F3 errors for most GE's and it looks like it is related to the temperature sensor/sensing.
I would remove the temperature sensor and check it with a meter, see below.
Also check the the connection to the control board is clean.
If the sensor is OK the control board is probably toast.
Here is a good site
http://www.applianceaid.com/elecrange.html
Check out 7, 8 and 21
#3 Posted : Friday, November 6, 2009 11:36:02 AM(UTC)
Thanks for your help. I tried to find a replacement sensor but everyone says it is discontinued. I will pull the oven and and check the connections. Turning off the breaker to the oven seemed to reset the oven but not completely. I like the oven and I'd hate to replace it but it may be more cost effective to do just that.
#4 Posted : Saturday, November 7, 2009 5:07:32 AM(UTC)
This would be more consistent with a control board problem.
If you can confirm that it is just a sensor problem, I would take the sensor to a decent sized appliance parts store. They may be able to find a sensor that is close to yours. What is important is how far into the oven, the sensor reaches. You hay have to drill a new hole in the back wall for the mounting screw (not a biggy). Also the if the connector is different just cut the wires off the old one and splice onto the new one. Use the black bakelite type of wire nuts as they are more heat resistant.
Just about all sensors are the same as far as temperature/resistance.
