I have a Maytag Epic Z date code 2009, it will run wash cycle and then stops after about 10 seconds into the spin cycle. The error codes are F24 and F28. I replaced the water temp sensor. no help. I run the diag test and stop in the diag with the spin cycle again. After reading a few forums, I replaced the door latch. No help. Its a Maytag Epic Z HMWZ400TQ02 the F24 is a water temp sensor and F28 is a communication error.Neither seem to have to do with the machine stopping during the spin cycle.
