AndyBonner
#1 Posted : Saturday, September 3, 2016 8:29:21 AM(UTC)
AndyBonner
Hi: I hope someone can help.
Our Jenn-Air JES9900BAS oven has 2 problems:
1. The convection oven takes a long time to heat and never reaches the set temperature
2. The Bake setting reaches temperature but does not maintain the setting. It slowly reduces over time.
I have recently replaced the control panel for other issues.
No fault codes appear.
Thanks in advance
-Andy:)
AndyBonner
#2 Posted : Saturday, September 17, 2016 3:13:14 PM(UTC)
AndyBonner
Jenn-Air Bake temperature issue was solved with a new door seal :)
But the convection oven slow heat problem remains.
I think that will need a continuity check for 16 Ohms to see if the element has higher resistance, that may account for the issue. If not a new control module.
Cheers
-Andy
