wvonstockhausentappan
#1 Posted : Saturday, August 27, 2016 1:14:49 PM(UTC)
Top part works.Broiler work.In Bake mode igniter comes on and start glowing but no gas ignition.:confused:
I see gas supply to bake and broil comes from the same tube. Is there a change valve somewhere where it doesn't switch to bake. How long has the igniter glow for the gas to come out. The broil was pretty quick.
abadfish66
#2 Posted : Saturday, August 27, 2016 10:36:58 PM(UTC)
abadfish66
Sounds like you have a bad bake glow bar. If you can get amperage reading on the bake glow bar while its glowing it should read 3.2-3.6 amps. if it reads 3.2 and below, it's a bad glow bar.
#3 Posted : Sunday, August 28, 2016 7:10:07 AM(UTC)
Thanks for theresponse.
I took the "glow bar" out since it is glowing only orange in the center and not glowing almost white over the whole element like the broil glow bar. I measured the resistance its 0.5 Ohm. So its not open. What's the voltage ?
