Margiem
#1 Posted : Monday, August 22, 2016 2:47:54 PM(UTC)
Margiem
I have a Kitchen Aid stove and the oven won't shut off. All burners and clock work. The error message is 06 then on the next line down it shows AM71 U173 EEKEO-068. Does anyone know what this means?
#2 Posted : Monday, August 22, 2016 4:17:14 PM(UTC)
In order to provide most accurate advise we need the complete model number of the stove.
You can find it: on the frame behind the bottom drawer, on the oven frame behind the door or under the top panel.
Thank you.
Margiem
#3 Posted : Monday, August 22, 2016 4:20:20 PM(UTC)
Margiem
MODEL NUMBER Ykera807ps00
Margiem
#4 Posted : Monday, August 22, 2016 4:29:39 PM(UTC)
Margiem
I have to turn the breaker off in order to get the stove to turn off. When I turn the breaker back on the clock comes on and the burners and oven work but the oven still will not turn off.
#5 Posted : Monday, August 22, 2016 7:39:48 PM(UTC)
According to the tech sheet, the error code should start with F following by one digit, then E with one digit. The error code you described is not valid for the model number you posted. Please verify and repost the error code.
Thank you.
#6 Posted : Monday, August 22, 2016 7:42:34 PM(UTC)
Originally Posted by: Margiem Go to Quoted Post
...the oven still will not turn off.
Did you mean it stays on after the cooking was done or you not able to turn the oven off by pressing the Cancel button?
Margiem
#7 Posted : Tuesday, August 23, 2016 1:44:25 PM(UTC)
Margiem
Not able to turn the oven off after cooking. This is the correct code that comes up and the model number is correct. I have gooled the error and this seems to be common. It looks like it may be the switch membraine otherwise know as a keypad.
#8 Posted : Tuesday, August 23, 2016 2:34:29 PM(UTC)
If you are not able to stop the cooking cycle by pushing on Off button, the problem most likely caused by faulty membrane switch. If you need the correct part number, post the color of the touch pad.
Here are the parts diagrams for Kitchen Aid range Model YKERA807PS00
Kitchen Aid Stove Top Element replacement - trouble (Oven Repair (including Ranges and Cooktops))
by Mark Duess 1/22/2017 9:25:35 AM(UTC)
Ignitor for Kitchen Aid stove (Oven Repair (including Ranges and Cooktops))
by jlov@charter.net 5/21/2010 8:36:02 AM(UTC)
Kitchen Aid stove top repair (Oven Repair (including Ranges and Cooktops))
by kwright 10/26/2009 11:57:25 AM(UTC)
Kitchen Aid Stove Top Controls (Oven Repair (including Ranges and Cooktops))
by jmack 9/19/2009 7:34:56 AM(UTC)
