red_snapper
#1 Posted : Monday, June 13, 2016 3:43:27 PM(UTC)
red_snapper
Freezer door open..... flap manually closed:
dot dot pause dot dot pause.
Freezer door open.... flap open
Freezer door open..... interior light manually off
no infrared light at all.
Freezer door open..... interior light on
I have replaced the ice maker assembly before and have just recently replaced the rear water valve purchased from you.
The entire assembly just does not make ice at all.
The black water tube that goes into the cup on the ice maker is not frozen.
Does the infrared flash sequence signify it is not working?
red_snapper
#2 Posted : Wednesday, June 15, 2016 5:04:23 PM(UTC)
red_snapper
20 questions on the first page.......ZERO response from any tech.
Are you fellas on strike?.....
