I have a maytag fav6800aww that's worked fine for years until the other day it started overflowing and flooded my laundry room. It seems to run fine until the water starts overflowing out of the drum and onto my floors. I've checked the hoses for blockages and they're all fine, checked the water inlet valve for continuity and it checks out (mechanical failure? water pressure from the wall is fine though). My next thought is maybe the pressure switch or the pump is there a way to test these? Thank you in advance!!
