Hi there. I have an issue with our oven becoming too hot. At first I figured it was the thermostat, but now I am not so sure. When the oven reaches temperature, I can hear it click which is when the element would turn off, but it is staying on. I put a thermometer in the the oven and when it is set for 350 or so, it is actually reaching over 500 degrees. Any ideas, or should I just try a new thermostat? Thanks in advance.
You have been a member since:: 2/29/2008(UTC) Posts: 19,638
THIS FORUM IS DEAD!!!!!!! |
