yokozuna303
#1 Posted : Friday, November 6, 2015 2:15:33 PM(UTC)
yokozuna303
Greetings. My Bosch dishwasher got stuck at "1" minute remaining on the display, sounding like the drain pump was running continuously. When I opened the door, I saw that the detergent cake was undissolved and that there hadn't been much spraying of water during "cleaning".
So I ran the diagnostic test cycle, and the display ended up showing a "2" with the nearby two LEDs flashing. I checked the inlet valve, and plenty of water makes it into the machine (and coil resistance is 1k ohm).
QUESTIONS:
(1) After some Googling, I discovered that getting stuck at "1" minute, along with the diagnostic code of "2" during a test cycle, probably means that I've got a heating problem, right?
(2) But why would that keep water from being sprayed through the sprayers (which are very clean and clear of debris)? :confused: Seems like a recirculation pump issue.
Tonight I will check the control board for the infamous burned/missing solder joint, but I'd also appreciate any advice based on what I've posted above. Thank you!
yokozuna303
#2 Posted : Saturday, November 7, 2015 2:31:31 PM(UTC)
yokozuna303
Extracted the control board and found no evidence of a bad solder connection.
So I'm wondering what kind of failure could explain the "heating problem" as well as the lack of pressure in the spray arms.
The dishwasher worked fine up to the point that it failed...
