BIBS
#1 Posted : Wednesday, October 28, 2009 7:16:24 AM(UTC)
BIBS
The Dishwasher Runs All Cycles Ok But Whenit Comes To The End Leaks Copiously.
Several Local "repairmen" Checked It And Cannot Find The Leak.
I Don't Have The Installation Maual.
Think It May Be The Corrugated Hose Cracked (but Not Visible).
Appliance Is Properly Leveled.
1) What Could It Be?
2) Where Can I Dowload An installation Manual (not User Manual)
#2 Posted : Wednesday, October 28, 2009 11:27:20 AM(UTC)
Here is the install manual
http://shared.whirlpoolc...erature/JDB4950AWFII.pdf
This should also be useful
http://www.servicematters.com/m...ibrary/docs/16009308.pdf
Hard to say where it is you may have to pull the unit out to find it.
I would unplug or flip the breaker to remove power from the unit.
Reach back and dry the unit off as best you can.
Then run a cycle to try and find the leak.
A small mirror and a good flashlight are very helpful here.
The type of mirror that is on a handle like the ones a mechanic uses are ideal (a lager version of a dentist's mirror).
You could just tape it to a piece of doweling.
I do not like sticking my arms under a unit when it is running.
