Tagyourit
#1 Posted : Tuesday, March 3, 2015 3:21:42 PM(UTC)
Tagyourit
My Calypso washer touch pad has gone blank, it is as if the machine is getting no power. I have checked multiple outlets, every once in a while the error code FL shows up but then if I hit cancel the touch pad goes blank again. I have changed the control board, no luck, I have change the line filter no luck. The only other thing I hear mentioned on the net, is the drain pump going bad, but I'm not sure if a bad drain pump would effect the touch pad and make it go dark. Anyone encounter this problem and know a fix.
