The oven and broiler work fine for a weeks/months at a time. Periodically, the oven will only warm, regardless of the temperature set. After turning the oven on and off a few times, it eventually kicks in. I read a few threads with similar issues. Is there a way to know if the faulty part is the thermostat, igniter or the heater tube holes without replacing all parts?
