Keuka
#1 Posted : Wednesday, December 31, 2014 7:09:48 AM(UTC)
Keuka
The START button on the touch pad stopped working. The other buttons work okay. Sometimes I can make the START button work by rubbing across it rather that just pushing it. I have heard that it could be a moisture problem and that I should remove the membrane switch to let it air dry. If so, how do I do that or is it likely to be another problem?
GE Oven - touch pad problem (Oven Repair (including Ranges and Cooktops))
by tinamonsaas 12/2/2020 7:23:09 PM(UTC)
