novice mike
#1 Posted : Tuesday, November 18, 2014 12:02:00 PM(UTC)
novice mike
My mother has a wall oven/microwave combination model 306bwh2 which is 20 years old. The self cleaning recently quit working. As there is no lock on the door when it is in self cleaning mode, I'm wondering if the problem is a sensor or switch of some sort and if so how involved is it to fix
#2 Posted : Wednesday, November 19, 2014 2:21:16 AM(UTC)
Parts for KitchenAid KEMS306BWH2 Oven - AppliancePartsPros.com
[COLOR="Blue"]
I'm wondering if the problem is a sensor or switch of some sort and if so how involved is it to fix[/COLOR]
Yes it could be a switch etc.
You will have to check the self clean circuitry with a meter to see if all the interlock etc. are closed when you go into self clean.
Could be one of the switches on the door lock mechanism is not closing.
I do not recommend going into the control section in the unit unless you have some electrical experience.
On many older units disconnecting power from the unit does not discharge the microwave power capacitor and this hold lethal voltage levels.
File Attachment(s):
KEMS306.pdf (1,054kb) downloaded 0 time(s).
GE stove. Self cleaning not working (Oven Repair (including Ranges and Cooktops))
by dihahey 6/9/2015 4:31:34 PM(UTC)
