Captain Offshore
#1 Posted : Tuesday, October 14, 2014 11:15:25 AM(UTC)
Captain Offshore
Hope some one out there can give me a suggestion or two. first of all i don't think this model has a interior light ,if it dose it doesn't work. And can't find it. This is what it dose in the different modes:
Auto Sense: turns on only (no heat) if you hold start in and turn the switch thru the range starts at "Less Dry/Cool" for a few moments, after that doesn't run.
Timed Dry Low Heat: Works thru the whole range with out heat , need to hold start button all the time.
Timed Dry High Heat: doesn't work thru whole range with the button held or not.
No Heat Fluff: no operation holding start in or not.
I've checked thermal fuse (12 ohms) and also on the heating elements (12 ohms). That is as far as i have gone.
fairbank56
#2 Posted : Tuesday, October 14, 2014 12:51:00 PM(UTC)
fairbank56
Groups: Expert
Sounds like you have a faulty timer and faulty motor. This low end dryer has one of those junk timers that is a high failure item. The fact that you have to hold the start button and have no heat indicates a failed motor switch which requires replacement of the motor.
Whirlpool W10185972 Timer - AppliancePartsPros.com
Whirlpool 279827 Dryer Drive Motor - AppliancePartsPros.com
Eric
Captain Offshore
#3 Posted : Tuesday, October 14, 2014 1:24:40 PM(UTC)
Captain Offshore
WoW this look like about 1/2 the cost of a new dryer.
Thanks for your response I'm going to sleep on this and relook it over in the morning.
Thanks for your advice,
Denny
