I already watch the video on how to removed and replaced the tub seal, now I cannot remove the inner tub it seem like its stuck, how do I unstuck the inner tub without destroying the tub itself. any body have the same problem that I have. pls help:confused:
When you remove those four screws that hold it down it should lift out. Can't tell why you are having a problem. Try putting some very hot water and liquid detergent in there to see if that will loosen things up.
