AppliancePartsPros.com
Appliance Repair Help
Washer Repair
what size drill bit to remove GE control panel screws
Can anyone tell me what type/size bit or allen wrench is needed to remove the screws from the back of the control panel? The screw part is listed as a size 8-18b GE part # AP2045301. Is it a Torx or double hex??? Thanks
A good set of torx bits should provide you with the right size. The size is fairly common and usually comes in even inexpensive tool sets.
Washer Repair
