I have a whirlpool washer that has worked fine until a few days ago. Set the load to small and the temp to cold and hot water comes out. Rinse cycle is also hot. I changed out the fill valve and problem is the same. Hoses are still connected as the should be. Hot to Hot, Cold to Cold. Any help would greatly be appreciated. Thanks
Groups: Expert
Holy cow. I'm a dumbass. Wires were crossed. Now works great.
Groups: Expert
You failed to mention that you had serviced the washer before this happened.
Eric
