robert joyner
#1 Posted : Saturday, March 29, 2014 11:23:44 AM(UTC)
robert joyner
whirlpool wasing machine do not spin or drain
avemaria
#2 Posted : Saturday, March 29, 2014 10:13:55 PM(UTC)
avemaria
first off is the motor running during the spin 'cycle'? if it won't drain you may need to check your pump.. if it's not spinning at all it might be the basket drive block.. over time this may wear down.. if it doesn't grip properly, the tub won't spin.. another thing to check if the tub isn't rotating up to speed (or if it's totally worn it won't spin at all during spin cycle) is the clutch assembly.. these are all easy fixes.. just input your model number and find the schematic for your machine.. find the part numbers and do a search on them.. appliancepartspros.com usually has install videos to go along with these parts..
i'm assuming you have typical old style agitator, non computerized, machine like mine.. i'm not familiar with the newer machines that are computerized..
fairbank56
#3 Posted : Sunday, March 30, 2014 4:28:39 AM(UTC)
fairbank56
Groups: Expert
If the motor is silent during drain/spin, it's most likely a faulty lid switch.
Whirlpool 279347 Door Switch Kit - AppliancePartsPros.com
Eric
washing machine repair (Washer Repair)
by jeffsdad 1/4/2016 2:56:40 PM(UTC)
by jeffsdad 1/4/2016 2:49:43 PM(UTC)
by robert joyner 3/29/2014 11:23:41 AM(UTC)
by maindrain 5/8/2012 9:29:13 AM(UTC)
Washing Machine Repair (Washer Repair)
by CAC 1/5/2011 9:48:17 AM(UTC)
Washing Machine Repair (Dryer Repair)
by avery208 12/6/2010 11:02:19 AM(UTC)
by sbell63@rr 10/1/2010 4:53:04 PM(UTC)
whirlpool washing machine repair (Washer Repair)
by igtaylor3@msn.com 7/21/2009 6:39:44 AM(UTC)
Washing machine repaired (Washer Repair)
by noi 7/6/2009 3:03:53 PM(UTC)
Washing Machine repair (Washer Repair)
by dqf 9/24/2008 5:29:18 AM(UTC)
