I am trying to remove the inner tub on my whirlpool washer. I have removed the spanner nut on top and there is also 4 tabs I believe from the outer plastic tube protruding through the inner tub center support. I depressed those but it still will not budge. I even had my son lift up a bit while I tried to tap down on the drive block but nothing. What am I doing wrong ? Can I just use a jaw puller and pull tub and drive block out together? Thanks, Dave
Groups: Expert
These can be a bear to get loose especially on an older model such as this one (16-17 yrs old?). Have two people lift up on tub while you rapidly tap the top of the dirve block with hammer and drift. Make sure your only hitting the block and not the drive tube. Also grabbing one side of tub and rock it as hard as you can back and forth.
Eric
Originally Posted by: fairbank56 These can be a bear to get loose especially on an older model such as this one (16-17 yrs old?). Have two people lift up on tub while you rapidly tap the top of the dirve block with hammer and drift. Make sure your only hitting the block and not the drive tube. Also grabbing one side of tub and rock it as hard as you can back and forth.
Eric Hey Eric, thanks for the reply. I just tried that and cannot get it to budge. What do you think about trying to use a puller to get it off. I was going to spin the nut back on but loose and pull from it to the top of the shaft and try and pull tub and drive block together. Dave
Groups: Expert
I would not recommend it, you could damage the thrust bearing and ball bearing that the bottom of agitator shaft sits on in the gearcase.
Eric
