jdn9580
#1 Posted : Saturday, January 11, 2014 10:15:13 AM(UTC)
jdn9580
Doesnt drain completely after rinse cycle. Bottom tub fills almost to top of tub.
#2 Posted : Sunday, January 12, 2014 1:49:16 AM(UTC)
Parts for GHDA696PSS - AppliancePartsPros.com
Looks like there should be a couple digits between the P and the SS.
Choose a unit from the Matching Model Numbers section.
First check that the drain tube is clean. A common place for crud to collect is where it attaches to the house plumbing.
Check tat the filters are clean.
If you click on the picture or description of the drain pump (item 17 in section 04) a new page will open with more views. You will see a back flow flapper valve (red) perhaps that has moved or is plugged open.
