I looked up the part number for the inner tub for an 80 series (11082872820) and 70 series washer (11023832100). They are both: W10389328.
However, correct me if I am wrong, but isn't the 70 series considered a 3.5 cu. ft. washer and the 80 series consider a 4.0 cu. ft. washer? Does this mean if I replace the inner tub we can wash more laundry at once?
What are the tell tail signs of a bad inner tub, or maybe a better question to ask is what reason do most people replace them? Also, has anyone put one of these inner tubs in a 70 series washer and what were your results?
Groups: Expert
The Kenmore series numbers do not correlate to any particular tub capacity. That depends on the individual model. Model and series are two different things, with "series" being a marketing gimmick and doesn't really tell you much about the washer.
Eric
