rangerjoey76
#1 Posted : Sunday, December 8, 2013 11:55:34 AM(UTC)
rangerjoey76
My washer won't agitate. It will drain the water and then just sit there with the pump still running. I checked the belt, its in good condition. I checked the lid switch and it is working property. Motor and pully move freely. What next?
rangerjoey76
#2 Posted : Sunday, December 8, 2013 11:57:40 AM(UTC)
rangerjoey76
Also it doesn't seem like the motor is trying to run or do anything. Does this model have fuse or something I can check? This model doesn't have any light indicators on it.
fairbank56
#3 Posted : Sunday, December 8, 2013 12:21:47 PM(UTC)
fairbank56
Groups: Expert
No fuse on this model. Check the motor connector for burned/corroded wire terminals or broken wire at terminal connections. My information shows this washer having several status LED's. Pull the tech sheet from inside the control panel. It will tell you how to get into service mode to check for any error codes but they are displayed using the status LED's. Do you have a multimeter and experience using it to check voltages at motor connector?
Eric
rangerjoey76
#4 Posted : Monday, December 9, 2013 4:53:39 AM(UTC)
rangerjoey76
I have a multi meter, but can't say that I am that experienced at what you are asking.
rangerjoey76
#5 Posted : Monday, December 9, 2013 6:13:19 AM(UTC)
rangerjoey76
No power going to the motor at all. All switches seem to be working properly. Talking to my local appliance repair store we have narrowed it down to replacing the main control board. At $180 this doesn't seem very practical for a 15 year old washer.
fairbank56
#6 Posted : Monday, December 9, 2013 6:44:34 AM(UTC)
fairbank56
Groups: Expert
Check for 120vac at the control board 6-pin connector between the yellow wire and the red/white wire. If you have 120vac there, washer fills and drains but never any noise from the motor, then I agree that it's the control board.
Eric
rangerjoey76
#7 Posted : Monday, December 9, 2013 7:05:31 AM(UTC)
rangerjoey76
Yup, 120 volts there, thanks.
ge washer wont spin or agitate (Washer Repair)
by outback32 9/29/2015 9:46:08 AM(UTC)
