My washer is not draining properly. I replaced the pump and checked the drain hose was clear. My clothes are wetter than normal after a cycle. The next day after running a load and the washer sits empty for 24 hours, it fills up with water and there is 2-3 inches in bottom of tub.
Any suggestions on how to fix the problem? Thanks
Groups ready for retrieval: Registered
I have the same problem, was wondering if replacing the pressure switch might help. Does the pressure switch signal the pump to stop when it thinks there isn't any water left?
