jpurdy
#1 Posted : Tuesday, November 26, 2013 5:49:02 AM(UTC)
jpurdy
My Frigidaire electric stove makes a terrible screeching sound when I try to use the oven, broil or convection oven. The electric cooktop part works fine, just cant use anything else. I would assume this type of noise could only result from a moving part, but since I cant use the oven or broil either... (they don't require a moving part such as a convection fan/motor) doesn't make sense.
Could this be an electrical problem.... like a shorted control switch? The last time I called a repairman, they couldn't make heads or tales and wanted to replace parts to eliminate possibilities (at my expense). Yes, Thanksgiving is in two days, I'm in no great rush, just want to correctly identify possible problems.
Thanks, any help would be appreciated.
#2 Posted : Tuesday, November 26, 2013 8:07:25 AM(UTC)
Parts for Frigidaire GLES388DBB Range - AppliancePartsPros.com
The unit has two fans.
The convection fan and a cooling fan (item 108 in section 05) perhaps it is making the racket.
