lhull
#1 Posted : Saturday, November 16, 2013 5:10:42 PM(UTC)
lhull
We have a full size Frigidaire refrigerator with a full size freezer combo. The seam on the back wall down toward the bottom has opened on each unit. Has anyone ever seen anything like this. Cold air on each side is obviously escaping. Any input would be great. Thank you.
Appliance Ninja
#2 Posted : Saturday, November 16, 2013 7:04:29 PM(UTC)
Appliance Ninja
Actually, the insulation is blown in and fills all the voids and crevices. It is not likely that you are losing any cold air, but the cracks can be unsightly. There is a repair kit out that is designed for this problem. It is available below. You can also try a white silicone type caulking but may want to use a food grade type.
Whirlpool 8201700 Liner Repair Kit - AppliancePartsPros.com
lhull
#3 Posted : Saturday, November 16, 2013 7:29:03 PM(UTC)
lhull
The crack goes clear across the seam. It has opened at least an inch wide. Has even developed a rust spot and cracking of the inside paint several inches above the crack in frig part. Any causes for this to happen? It seems like it would be a defect of some sort. Appliances are 6 years old.
Appliance Ninja
#4 Posted : Sunday, November 17, 2013 6:37:02 AM(UTC)
Appliance Ninja
Wow, that is larger than most I have seen! Can you post a picture of it? The cracking is usually due to expansion of the foam insulation but usually results in hairline cracks, not large ones like you apparently have.
#5 Posted : Sunday, November 17, 2013 6:39:49 AM(UTC)
I would call Frigidaire
Be sure to have your model number.
Find your model number - AppliancePartsPros.com
Also would not hurt to search the net using that model number to see if others have complained about this.
