Blueant
#1 Posted : Sunday, October 6, 2013 2:15:59 PM(UTC)
Blueant
Hello,
I have a 1997 Maytag Stackable DS9904 Washer/Dryer,
white membrane switch controller unit, no knobs...electric.
The Dryer Heater quit working after 17 years of great service.
Removed 45 deg. angled front cover.
I removed and checked the Element:
measure 11 ohms and see no opens, shorts, or wire discoloration.
Checked the black round Thermo switches, left/ right side in rear.
Both measure continuity, and what looks like
2 ceramic thermal resistor blocks, they show continuity also.
I removed and tested in-circuit also, the Heater Element control [COLOR="Red"]Relay[/COLOR]
(on the right side) bottom coil leads show 22 volts on, zero off.
I also see it physically activate thru plastic shell.
So it tells me controller and relay seem to be working...
I measure nothing across the 2 load wires [Thick Black/[COLOR="Sienna"]Brown[/COLOR] ]
during the Dry cycle...But it shows 108 vac during air fluff.
is this suppose to be 220 vac? Did I lose a phase?
Perhaps there's another Thermal ckt I have not found..?
I see the Relay black wire runs to 220 Terminal block.
(didn't remove cover)
but the brown wire, I have not traced all the way inside the unit.
Disappears behind a vent shroud..
Maytag changes the color to [COLOR="Indigo"]purple[/COLOR] then[COLOR="Sienna"] brown[/COLOR] again...bit irritating.
I would like to order a schematic if one can be found.
Blueant
#2 Posted : Sunday, October 6, 2013 9:24:58 PM(UTC)
Blueant
Beginning to think it's the 220 [COLOR="Red"]vac[/COLOR] outlet, I measure 108 vac across L2, L1...I'm assuming I should get 240 vac....don't know how I could've lost power.
#3 Posted : Tuesday, October 8, 2013 3:22:33 AM(UTC)
I cannot find any info on the given model number.
Please check it.
I tried at AppliancePartsPros, Sears parts and the Whirlpool/Maytag site and nothing comes up.
I am assuming this is a north American unit.
Unplug the unit and check power at the wall receptacle
Should be:
L1 to Neutral = 120 volts
L2 to Neutral = 120 volts
L1 to L2 = 240 volts.
Note that sometimes a breaker can loose half the line without tripping fully.
Turn the breaker off then on.
Often this is just something that happens and it is a one of or very rare event.
Sometimes it is either a machine or a wiring problem.
Blueant
#4 Posted : Saturday, October 12, 2013 5:08:33 PM(UTC)
Blueant
I went into a junction box where the 220 v [COLOR="Red"]a.c.[/COLOR] feed was in my 1949 House.
Measured 120 volts.
I found a wire nut had lost grip on the white phase wire. It visibly looked o.k. but was not connected physically upon closer inspection.
Re-installed wire nut. Measured 220 v a.c.
Turned on my Dryer, wha-la, heater element started glowing...cool.
Guess I tore apart my Dryer for nothing and should've checked simple things.
