maxy212
#1 Posted : Wednesday, October 2, 2013 7:01:34 AM(UTC)
maxy212
My washing machine doesn't fill with water when on rinse cycle. :(
fairbank56
#2 Posted : Wednesday, October 2, 2013 10:07:58 AM(UTC)
fairbank56
Groups: Expert
Rinse is cold water only. Are you able to get cold water wash? If so, after spin stops, push timer knob in and advance a click or two and pull out knob. If it still won't fill, probably have a bad temperature switch.
http://www.appliancepartspros.c...w10184148-ap4358828.html
Eric
maxy212
#3 Posted : Wednesday, October 2, 2013 1:32:20 PM(UTC)
maxy212
The washer will not fill for rinse cycle. The wash cycle works and all of the other things work, it drains, spins, agitates, but just won't fill with water on the rinse cycle.:(
fairbank56
#4 Posted : Wednesday, October 2, 2013 1:41:13 PM(UTC)
fairbank56
Groups: Expert
maxy212
#5 Posted : Wednesday, October 2, 2013 3:08:22 PM(UTC)
maxy212
:confused:
We have already replaced the temperature, switch and yes the washer works in all the temperatures, on wash cycle, and have done the push in advance 1 and 2 clicks, still won't fill on rinse cycle;)
Whirlpool W10184148 Atc Switch Mid Level - AppliancePartsPros.com
Eric
oklanyes
#6 Posted : Saturday, July 25, 2015 11:31:23 AM(UTC)
oklanyes
OK - mine wasn't filling on the cold water side (and I didn't need hot water) so I just switched my hoses to trick it. Now the washer fills fine when I begin in the wash cycle - agitates drains and everything, but then will not fill up with water for the rinse cycle. Is it becuase then it knows I don't have any water to the "cold" hose in the back becuase I have swapped them? So what do I do to fix the cold side. the water in the wall runs fine through the hose on the cold water side, I've checked the little screen where you screw in the hose to washer and its clean, but the water will not go into the washer (it isn't draining in the drain hose) it just isn't going into the washer at all on the rinse cycle...
Help - Maytag Washer Won't Fill On Rinse Cycle (Washer Repair)
by oklanyes 7/25/2015 11:23:28 AM(UTC)
Roper washer won't fill on rinse cycle (Washer Repair)
by goff 12/13/2014 12:14:56 PM(UTC)
Washer won't fill on rinse cycle unless between 2 settings (Washer Repair)
by jkaszer 6/2/2013 11:11:50 AM(UTC)
Washer won't fill on rinse cycle (Washer Repair)
by tmwalker3 8/13/2011 6:19:45 AM(UTC)
