hanmore
#1 Posted : Sunday, August 11, 2013 4:31:55 AM(UTC)
hanmore
how do I remove the blower motor
HumboldtRepairMan
#2 Posted : Sunday, August 11, 2013 6:35:43 AM(UTC)
HumboldtRepairMan
Look at the schematics on this site..........disassemble machine.......take an adjustable wrench and locate the motor shaft and you'll find a flat spot somewhere on the shaft and put the wrench on it.........then go on the front side of the blower there should be a nut take a socket to it and make sure you're either holding the wrench on the motor shaft or have it lodged in a place that stays...........you may have to spin the blower wheel off in a reverse direction. good luck
Restricted airflow after repairman installed new blower wheel (Dryer Repair)
by Guest 6/1/2024 5:28:38 PM(UTC)
Maytag electric dryer blower wheel wear (Dryer Repair)
by Guest 1/1/2024 7:44:11 AM(UTC)
Whirlpool Oven GBD307PDS7 Shuts down and Upper Blower fan does NOT work (Oven Repair (including Ranges and Cooktops))
by rswilson1844 12/3/2023 11:18:33 AM(UTC)
Humming/Rattle After Blower Wheel Replacement - GE Dryer (Dryer Repair)
by PISCDryer 11/8/2023 7:10:25 AM(UTC)
Alternate blower wheel for dryer (Dryer Repair)
by Guest 5/6/2023 5:23:57 AM(UTC)
Bosch AXXIS dryer - how to replace blower belt?? (Dryer Repair)
by Guest 1/5/2023 3:41:46 PM(UTC)
wgd5300sq0 new dryer motor and blower wheel. But blower wheel keeps falling off (Dryer Repair)
by Ebnuno 2/6/2022 7:55:20 AM(UTC)
Dacor RV36B blower motor (Oven Repair (including Ranges and Cooktops))
by maico996 10/8/2021 3:22:14 PM(UTC)
new blower motor vibrates (Heating, Ventilation, and Air Conditioning (HVAC))
by rleescott 3/6/2021 12:21:07 PM(UTC)
Whirlpool blower belt (Dryer Repair)
by Jullee41 1/30/2021 11:37:08 AM(UTC)
Electrolux dryer blower shaft part (Dryer Repair)
by Pdavissmith 1/20/2021 1:01:07 PM(UTC)
Maytag dryer blower belt (Dryer Repair)
by kay edman 1/12/2020 9:20:19 AM(UTC)
Replaced Blower Motor, Dryer Air Now Seems Too Hot (Dryer Repair)
by sherrea 11/22/2019 8:02:54 AM(UTC)
Maytag DE 410 Blower Wheel Broken (Dryer Repair)
by Eeshen 12/26/2018 7:06:34 AM(UTC)
dryer blower wheel replacement (Dryer Repair)
by lancehenley1 12/4/2018 11:42:59 AM(UTC)
