The far left of the 3 dials-- the one that selects the load size and hence the water level-- seems to be stripped. It used to make clicks when turned, but hardly clicks any more and always fills to the same level all the time now, no matter where I set it on the dial. Need to know which part to order to fix this. Thanks!
the problem is in the lower part you need to fix it up. click here >>> REI Coupon Code
Groups: Expert
