Think I need a control board, but I haven't found this specific problem on any appliance repair site as of yet - our oven turned on by itself, bottom coil only, and eventually locked the door and displayed F3 E2.
The only way to turn it off was to flip the circuit breaker. Next day, we turned breaker back on, the door unlocked, but the coil started heating up again and OFF button didn't work, so we killed the breaker again.
I checked the ohms on the sensor and it was 1078, so seems ok. Besides, I don't know how a bad sensor would cause the oven to come on by itself.
Do we need an EOC board or is there something else I'm overlooking? Thanks.
