Ice maker not making ice. Removed ice maker and checked, nothing seemed to be hangin up. Water to the door works so I know there is water to the refrigerator. I made sure the drop tube was not frozen up and it was fine. I unplugged and reset the unit. When I closed the flapper on the left side of the door the red light on the right side came on for a second or two and then went out. Unit not cold enough to make ice? I know there are codes for when the red light blinks but what does it mean when it is not on. Thanks.
What is the complete model number of the refrigerator?
What is the exact measured temperature in the freezer?
