My stackable washer isn't starting, but dryer works fine. What is the likely part to be defective?
Originally Posted by: changa My stackable washer isn't starting, but dryer works fine. What is the likely part to be defective? Changa, The first thing to check, is the lid switch assembly Part number: AP2947199
and wiring to the washer portion of the laundry center.
Groups: Expert
Does it fill with water? I believe the lid switch on the thin twin washers only effects drain and spin.
Eric
Originally Posted by: fairbank56 Does it fill with water? I believe the lid switch on the thin twin washers only effects drain and spin.
Eric You're corret, my mistake. If the washer won't fill or wash, then there would be a broken black wire, between the timer and line cord connections or a faulty timer Part number: AP2974739
