G4cp3o
#1 Posted : Wednesday, February 20, 2013 6:03:07 PM(UTC)
G4cp3o
I replaced the microcomputer circuit board associated with an F7 error code it had a burned out diode or relay circuit. I have since replaced the inverter board as well not sure I needed too. Plugged in the microwave and it heats like a charm without the error code, but the magnetron cooling fan doesn't come on to keep it cool. Where do I go next? If it is something unreasonable I will pull the parts and send them back. The unit was used up to 3 years before the problem and hasn't been used in about 1 year. I would rather fix it but will not put more than it's worth to replace it with something new.
Thanks,
Rick Entrekin
Simon / APP Team
#2 Posted : Thursday, February 21, 2013 3:35:38 PM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
Do you have the pat number of the board you replaced?
Simon.
G4cp3o
#3 Posted : Friday, February 22, 2013 8:35:51 AM(UTC)
G4cp3o
8206064 Control board
Simon / APP Team
#4 Posted : Friday, February 22, 2013 10:41:41 AM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
Check if there is 120VAC at the motor plug. If yes - replace the motor, if not - replace the relay board again.
Post the results.
Simon.
